not staying on white smoke d15b1
Discussion in 'HYBRID -> ED-EF / DA' started by crxpower24, Feb 12, 2015.
  1. crxpower24
    crxpower24 Member
    So I bough a 89 civic 4 door from my brother and the car seems to stay on for a bit then die the spark plugs have oil in them I clean them n nothing I change the tps but nothing its throwing a bunch of white smoke can anybody give me ideas on what's wrong with it and yess I done reaserch but I can't find any ideas and it doesn't have any check engine lights
  2. Briansol
    sounds like you might need to do a headgasket.
    is it throwing any codes?
  3. crxpower24
    crxpower24 Member
    No code at all just keeps dying someone told me it might be my dizzy
  4. Solomon93
    Solomon93 Member
    White smoke = WATER. After the engine dies. Remove all spark plugs and while watching the valve cover, crank motor over.
    Does any fluid spray out? Sounds like a blown head gasket. Runs till it fouls the plugs.
