not sure if in the right question area !?!?
jelma1854
is there a way to get a diagram on how to put the batttery of a honda crx in the back from the fron of the car(like in the hatchback area) any info would be appreciated...thanx in advance
not really....just wanted to know if it is possible to move the battery for room for the engine (once again not my idea)...i would let it where it its
yes, you can move it to the rear hatch area, you just have to extend the wires (best to run new ones under the car) to the hatch area and ground the wires in the hatch area. After that, you should be good to go.
Most tracks require an enclosed metal case to hold the battery if you want to run it there.
