NPR Pistons
Discussion in 'Engine Building' started by madracer, Dec 9, 2008.
  1. madracer
    madracer Boosting B16A2
    Has anyone heard and use these Pistons before???? They said it's rated and tested for around 350 and maybe a little over 350 Horsepower... it was also mention that it was made in Japan. The are low compression piston for a B16A motor and 81mm in size, I was thinking of getting these for a B16A build to make around 320 HP....with a Turbo setup.....
    Any help on this well be grateful
    thank you....
  2. formby
    formby learning in progress
    what you are buying is basically a set of cast b18a/b pistons. they will lower your CR but they are not forged.
  3. madracer
    Would they be good for boost??? holding around 320hp dail driver????
