nsx-legend
Discussion in 'HYBRID -> BA-BB /CA-CD' started by ferrarikiller, Jul 3, 2004.
  1. ferrarikiller
    ferrarikiller Senior Member
    Bay Area
    Didn't know where to put this so here it is. Has anyone ever heeard of swapping a nsx motor into a legend? Or if the heads will fit on the legend block?
  2. UnlimitedEK9
    UnlimitedEK9 Member
    Boise, ID
    Well it would probably be a pretty hard swap considering that the NSX is RWD and the Legend is FWD but it can be done...it just might cost quite a bit of money to do it...I don't even know a place to find an NSX engine either so that is probably going to cost a lot...I don't know if the heads will fit on the block either...If you plan on doing it keep us updated and good luck!!!
    UnlimitedEK9
  3. allbottledup
    allbottledup Senior Member
    Galloway, NJ
    thats a crazy ass swap. If you do it then good luck..but i dont know if it would be worth the money for the hassle it would be.
