o2 censor?
jdm2gen03
will my obd-1 motor and ecu run if i have a 2 wire obd-0 o2 censor in. and if not can i jus go grab a 4 wire o2 censor off any obd-1 car and use that.
No you can not use the 1 wire O2's you must use the 4-wire heated O2 sensor.
You can take them off quite a few cars actually =) not even just hondas
(however you'll have to rewire the connection, its still the same function)
I don't recommend Bosch O2's and if you would like a factory fresh O2 sensor from Denso, you can buy them from Rywire.com for $75 shipped. Cheapest price around.
