o2 Question w/ vtec
MONKEYTUNER
I am running a 90 Integra RS with a freshly dropped in b16a 1gen. I finally got my knock sensor fixed so I do not throw that code anymore now I am throwing a code 2 which I believe to be the code for my second o2 which I have not hooked up yet.
Will this prevent me from hitting vtec? if not what else should I check? I am running a pw0 ecu.
Please help...................
Mark :worthy:
No, the second o2' will just give you a flat spot while accl. I would suggest wiring. Dont just splice it in with the other o2 or anything.
[post=259348]Quoted post[/post]​
im new to the ls vtec and am also having that code problem. where is the 2nd o2 sensor? sorry to steal your thread man. This thread is the closest solution to my problem.
