melscott62
I have a 97 civic LX that has a bad cat. converter on it.....rather than spending the money to replace the cat I am going the bypass it. my problem is I assume that it will still give me the check engine light still. I have heard the if I can figure out the resistance the the 02 sensor is set for you can put a transistor on it to by pass it.
thanks
thanks
