O2 sensor help!!!
i just bought a 96 EX wiring harness to use with my B16A swap (obd2a)... the plugs for the o2 sensor does not match up... i need to know what to do!!!
well, you can try to take the b16a (obd2a) o2 sensor harness plug then cut the splice it on to the ex harness. This way the ex harness can now plug into your o2 sensors....thats what i did and it all matched up with the wire colors..well you can give this a try. Good luck
nevermind,... i figured it out... on the EX harness the O2 sensor is on the front of the header and on the B16A it's on the end of the header... so the O2 plug was coming out the front of the harness and not the rear... i just extended the wires... thanks guys!!!
