ok, ran into a small problem trying to install my new o2 sensor.
The new o2 sensor came with JUST the wires and the o2 sensor. The instructions told me I would need to splice and connect the wires from the new o2 sensor to the connector. No biggie right?
Well, I looked on the old o2 sensor and there were four wires. Two black, one white and one green. On the new o2 sensor there are also four wires. Two black, one white, and one blue.
So, I assumed that the two black go together (im hoping I got the corresponding ones right) and the white goes to white, and the blue wire on the new o2 sensor goes to the green wire on the old o2 connector.
So wired everything up, did a nice and pretty little job. I started my engine, and this WHINING noise was coming from my intake.
WTF ???????????????????
after 30 seconds, the whining got progressively louder, then stopped. Then a minute later, it started again.
Im thinking that I did not wire the o2 sensor up correctly? Maybe I should switch the two black wires around?
If anyone cares, it is a 96 civic ex coupe stock y8 motor. Working on the front (before cat) o2 sensor...
