melscott62
I have a 97 civic LX that has a bad cat. converter on it.....rather than spending the money to replace the cat I am going the bypass it. my problem is I assume that it will still give me the check engine light still. I have heard the if I can figure out the resistance the the 02 sensor is set for you can put a resistor on it to by pass it.
I have been told that I just need one that is between .1 and 1. when I went to get one they said I needed other specifics such as what olms and so on
does anyone know the answer to this?
Thanks
Thanks
