o2 sensor swap problems
deity
heres my problem. on my b20z i have a gsr stock exhaust header. it does not have an o2 sensor bung.
theres is also a header to cat clearence issue that i need a exhaust shop to fab up when i get this swap done.
would putting an o2 sensor bung into that extra extension ( which is before the cat ) be a good place to put the o2 sensor?
i figure i can kill two birds with one stone with getting a bung welded in there while its at the shop.
Primmarys before the cat. Secondarys after the cat. so that should be good but you need one behind the cat.
ya boy steveo
