O2 Sensor Wiring
R883
Hi
I have just put a D16Y8 in my 1997 EK3
The Y8 needs a four wire o2 sensor.
My old D15Z6 only used a 1 wire sensor.
I am wiring it just now and need a bit of guidance :confused:
I need to check my wiring is right
This is for my ecu
Connector A
6 - Heater Control
Connector D
7 - Sensor 1
11/12 - Sensor Ground
My o2 sensor wiring is
(got this from NGK)
Signal - Black
Ground - Gery
Heater - 2 x White
Now.....
I think my wiring goes
6 - Heater Control to Heater - White
I have two wires here what do i do ?
7 - Sensor 1 to Signal - Black
11/12 - Sensor Ground to Ground - Grey
I all ready have wire in these do i just splice these together ?
Or can i use any good ground ?
Does that look right ?
Am i missing anything ??
Cheers for any help !!
R883
I'm in to learn on this one, as I will be doing the same swap on my EK hatch soon, minus I have a Y7 in it now.
no idea man, im also in this to learn. i have a D16Z6 with a 4 wire O2 sensor and my old motor was a 2 wire. so im semi stumped... the grey and black wires are right, so im pretty sure. as for the 2 whites. im about as clueless as you are
