O2 Sensor
Discussion in 'HYBRID -> EG-EK / DC' started by mauger, Apr 23, 2003.
  1. mauger
    mauger Junior Member
    does it matter what 4 wire o2 sensor you use with a p28 ecu and if no how do you wire it up cause im conveerting from obd0 to 0bd1
    thanks
  2. D16z6CrxDx
    D16z6CrxDx Senior Member
    no that dosetn effect anything unless u have all the wires hooked up, but u MUST rout the wires from the fuel injector resistor box to the ECU b4 u run an OBD1 ecu..i make the obd0-obd1 adapters an peaple think its soo easy to convert but they forget to do vital fuel things that i tell em to do when i sell the jumper...
