o2 sensor
Discussion in 'General Tech and Maintenance' started by rex187, Mar 13, 2007.
  1. rex187
    rex187 Member
    austin,texas
    on my primary o2 sensor has gone out. i need a new one. i dont know if i need to get one off a intrgra or what? can anyone help me
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    what car is it
  3. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    as long as your car has a 4 wire 02, it doesn't matter if you go civic or integra, they are the same.
  4. rex187
    rex187 Member
    austin,texas
    i guess i should have said what car...its a 91 crx si with a b16a obd0
  5. AHHVTEC
    Alabama
    it does matter some ecu only use a one wire 02, so just look at your or and if its a 4 wire any honda 4 wire 02 sensor will work. if its a one wire buy a one wire, oh my bad i see your point nm lol
  6. rex187
    rex187 Member
    austin,texas
    ok the b16a obd0 has two 1wire oxygn sensors. the one that is fried is my primary oxygen sensor. i just need help finding out what honda or acura modles to grab one off of.
  7. rex187
    rex187 Member
    austin,texas
    by telling me that it has one wire or four. that still dosent help me any i still dont know the modle of honda to get one for. i think it needs to be obd0(right) buecause every thinkg after 92 on honda went obd1 wich has a 4wire oxygn sensor... myabe its a 3wire but i don know for sure with out going out side and looking at my 94 sedan
  8. AHHVTEC
    Alabama
    just get one from a obdo honda that has a one wire, like crx ect ect
  9. rex187
    rex187 Member
    austin,texas
    ok thank you thats was all i needed i wasnt sure ifthe crx sohc would work or not
