I have purchased a complete swap b18c GSR motor on ebay and i am having my mechanic swap it into my 1990 Honda civic SI (Hatch). Will i need OBD1 or OBD2?? I am planning on buy a hydro to cable converter for the tranny http://www.jprmotor.com/product_info.php?products_id=77 I guess i need to find axels and mounts. if any of you know where to find them, please let me know.
depends on what year the motor is, OBD1 will be a 92-95 motor and OBD2 would be 96 and up, and what ECU you have
You're going to cause yoruself a ton of headaches buying that engine off ebay. Did it come with a transmission? You bought a B series engine, if you don't have a B series transmission... you won't be able to drive it until you get a B series tranny. I hope the engine came with an ECU also.
Engine came complete swap with hydro tranny, ECU, intake/exaust manifold and everything in between. the person selling it to me asked if i need obd1 or obd 2. will either of these swap into my car? and will the part above work to convert the b hydro tranny to my clutch? thanks
you can put either one (OBD1 or OBD2) in your car. but, you'll need a jumper harness (Boomslang and Hasport make them) basicly, if you get the OBD1 motor/harness, you'll need a OBD0 to OBD1 jumper harness for the ECU.
