obd 0 block to obd2?????
Discussion in 'ECU's, Electronics, and Tuning' started by l4x4113, Apr 11, 2008.
  1. l4x4113
    l4x4113 New Member
    i have a obd0 jdm b16 bottom end and a obd2 american b16 head i wanted to know if there is a why to convert the bottom end to obd2 since the block comes stock without a crank position sensor on the crank timing gear like on the obd2 cars? the head i converted back to obd2 from obd1. i dont wanna do obd1. i would rather do obd2.
  2. OKCZombie
    OKCZombie Banned
    why would you rather do obd2? Unless it is for cali smog or something IMO there is no reason
    and I'm sure this would fit better in engine building or something
  3. BrutalB83
    Rochester Hills, MI
    :werd:
    Why would you want to go back to OBD2? OBD1 is infinitely easier to tune...
  4. l4x4113
    l4x4113 New Member
    bc i want to sell if after im done and the car will not pass inspection with a odb1 computer and i figured it out but thanks
  5. BrutalB83
    Rochester Hills, MI
    Gotcha, that makes sense...
  6. ludetech
    ludetech New Member
    nebraska
    where do you live? cause it should be fine with inspection unless your in cali. oh and all obd2 realy is, is for diagnosing to go to an obd2 setup you'll need a harness and a computer or a harness adapter like skunk2 sells.
  7. l4x4113
    l4x4113 New Member
    na i have a 99 gsr it has a obd2 harness
