OBD 0 to OBD 1??
CRseX84
hey i have a 91 crx dx, that i put a SI motor in so i had to convert to MFPI.. but now i have a d16z6 with a p28.. and thats obd 1... is there a conversion conector for the ecu that any one knows about?? also will i have to relocate the wires for the MFPI i did?? and where will i adapt in the Vtec for the z6?? any help would be awesome!! thanks also guys
Tyler
before posting, do a search for the infromation you need, converting to obd1 and wiring vtec has been covered 1321242452x over, just to help you out a bit though you need to buy a jumper harness, 4 wire o2, obd1/2 dizzy, ob1/2 injectors and harness clips, and ecu, hopefully most of that will be in your setup already
jkobdconversionharness.com is cheaper than them and i believe its jdmshit.com thats even cheaper than jk, i think it was like 110 shipped or something, also doesn't someone on here make em?
