Obd-0 To Obd1 Help
Discussion in 'ECU's, Electronics, and Tuning' started by OutOfSpecsCrx, Mar 22, 2003.
  1. OutOfSpecsCrx
    OutOfSpecsCrx Junior Member
    i have 88 crx si with a pr3, ls conversion. I want a p28, so i made the jumper harness. and that i know is wired right. so here is the question: do i need a different distributor?? perhaps obd1 dist? I heard I can just rewire the dist. but i can't find any info on that.
    asking the honda gods for help.... :worthy:
    ozy
  2. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    That is correct, you will have to use a OBD1 dizzy.
    Your best bet is to use a PR3 or PW0 88-91 ecu. It will cost you less in the long run.
  3. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    you will also need obd1 injectors....
  4. bossman032
    bossman032 Senior Member
    Their are 48 wires you need to mess with.
    I think you need to add 14wires to make it Into OBD1!!!
    Shit if confusing but you will have to loook into it before they make some sense you cant just say it without looking at the diagrams and compare it with what you have that will make more sense...
    good luck.. :ph34r:
