Domi31
Member
Ok I need to do a rebuild on my B16a2 (bad rings). But in the mean time so I can still drive the car, I plan on putting in a JDM B16 92-95 motor. I know about the problems with running a pre-obd electonics. But if I use the USDM IM, Dizzy, Oil Pump along with the USDM Wire Harness should I have any problems running my USDM ECU with this older motor? what problem will I run in to doing this Swap?
Im sure the mounts are the same so Im just looking at a long block B16, if I can get an OBDII I will, it just the OBD1 are cheaper and easlier to find.
