Obd 1 Or 2?
Discussion in 'HYBRID -> EG-EK / DC' started by Marcizo, May 8, 2003.
  1. Marcizo
    Marcizo Junior Member
    Yea, i just realized i don't know if my civic is obd 1 or 2. it's a 99 ex. i was planning to put an ls motor in it. and can you guys let me know which year(s) of the ls motor would be the easiest one to put. thanks :worthy:
  2. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    your car is OBD2, if you want to put an LS motor in, you need a motor from a 96-01 integra.
    obd0 = <91
    obd1 = 92-95
    obd2 = 96-2001 (the 01 civic is obd 2.5 everything else is obd2)
    obd2.5 = 2001+
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Not that it matters here,but the 99-00 Si is also OBD IIb.
  4. Marcizo
    obd2 gotcha, thanks. and now another question, would i save money buying the ls package(with the tranny), sell the ls tranny, and then buying a b16 tranny to put it in place, or is it cheaper to buy an ls motor(just motor) and buy a b16 tranny separately? :D thanks
  5. Baker
    Baker Senior Member
    Schaumburg, IL
    umm, you're probably better off getting a full swap then swapping trannies, thats what i did and it totalled to about $2000-2200 for and LS swap witha gsr trans
  6. pissedoffsol
    your car is obd2b
    you have two choices:
    #1
    2000 LS swap, also obd2b
    civics went to 2b in 99, tegs didn't until 2000.
    however, 2b ecu's have imobilizers built into the ECU's. so unles syou feel like swappign ingition shit,
    #2
    99 ls swap
    obd2a
    use civic harness. lengthen wires/ swap dizzy plugs
    get an obd2b ->2b conversion harness so you can plug the 2a ecu into your 2b harness
  7. Marcizo
    ok, from what i've heard (which i highly doubt is true) finding a 5 speed tranny on a ls motor isn't an easy thing to do. :unsure:
    anyways, does the ls tranny suck? or can i live with it for a while?
  8. xj0hnx
    C.C.TX.
    I though only the 99-00 Si was OBD IIb till 2001,when the other models also took it on.
  9. pissedoffsol
    nope, but buddies 99 ex is obd2b as well
