obd 1 to obd 2 help
Discussion in 'ECU's, Electronics, and Tuning' started by sounddude, Dec 22, 2006.
  1. sounddude
    sounddude New Member
    concord nh
    hey guys, i was wondering if you could help me out with this. i have a honda civic lx sedan which is obd2 (1999) i am doing an engine swap to a usdm b16a2. the only ones i can fine seem to be obd1. because nh is gay in order to pass inspection they plug a computer into the obd2 port. if i just used a wire harness to switch the obd1 to obd2 would that work with the test or would they know.
    also are there any sensors that i would have to replace.
    anything is helpful at this point.
    thanks a bunch
