I am trying to make a ECU jumper so I can put a JDM Integra Type R (P73) into a 88 Honda CRX HF. Does anyone have a chart that I could follow to make one? It would Help me out a bunch. Thanks
you won't find a chart, but if you use your brain I bet it won't hurt too bad.
Look up "OBD0-OBD1 conversion" OBD2 distributors are the same electrically and different physically. Convert to OBD1, and use the OBD2 distributor connectors and you'll be fine.
If I were you, I'd forget using the ITR ECU and get a chipped P28. Much less pain.
If I were you, I'd get a SiR (or ITR) cluster so you could keep the electronic VSS module.
