OBD II B16a in an EG
Discussion in 'ECU's, Electronics, and Tuning' started by Slammed90Lude, Mar 17, 2004.
  1. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    can we just use the harness on the motor (obd II) and plug it in to the car harness and just use an OBD I P30 to run this motor? help
  2. deth101
    deth101 Senior Member
    usa
    I'm using a 98gsr harness on my 00sib16a2 in my 95dx and it plugged right in,I'm having a mount problem tho :angry: ......but the harness plugged right in and works,I run a modded p72 but was told by many that the p30 will work
  3. Slammed90Lude
    milford, PA
    just i suspected....anyone else agree?
  4. SixtySecondAssassin
    Austin, TX
    if the harness you have is from an EK chassis then you cant. the ecu and engine harness is all integrated, intead of a two piece that diconnects at the pass. side shock tower like on our EG's.
    did you get your engine from a 99+ Si?
  5. Slammed90Lude
    milford, PA
  6. KYL174
    KYL174 Member
    HEY, I'M HAVING THE SAME PROBLEM BUT INSTEAD MY MOTOR IS A OBDII TYPE R. I KNOW I SHOULD HAVE RETAIN THE TYPE R MOTOR HARNESS, BUT INSTEAD I'VE USED THE HARNESS OFF MY 92'SI HATCH AND MADE SOME MODS. I CHANGED THE DISTRIBUTOR TO AN OBDI AND HAVE PROBLEMS COORDINATING THE COLOR SEQUENCE FOR THE ALTERNATOR. I'VE CUT THE ALTERNATOR PLUG FROM THE TYPE R AND SOLDERED IT TO THE SI HARNESS, BUT THE COLOR OF THE WIRES DID NOT MATCH. DO YOU GUYS KNOW WHICH WIRE GOES TO WHICH???THERE ARE FOUR WIRES......ANY HELP WOULD HELP. THANKS.
  7. BIGMAN
    BIGMAN Senior Member
    U.K
    yup, you can use a chipped p28 p30 or a p72
  8. radnulb
    radnulb Senior Member
    Sinsinnaty, Ohio
    sigh. This comes up over and over and over here...
    OBD1 Car
    OBD2 Motor
    use:
    -OBD2 motor
    -OBD1 (factory - use what came with your car. particularly important for VX) engine harness
    -OBD1 ECU
    -change pinouts on any sensors by splicing OBD2 connector on in place of OBD1 connector
    -Lengthen any wires that need to go to different places
    -Add any wires (vtec, vtec pressure, knock, etc.) that are missing. Run from sensor to shock tower and find the appropriate wire running through firewall to ECU.
    -Repin distributor (note: OBD2 distrib will run OBD1 car/ECU)
  9. radnulb
    Sinsinnaty, Ohio
    oh yeah, if you have a 92-95 CX or DX (BUT NOT NOT NOT VX!!!) you can get a 92-95 ex harness to have vtec and vtec pressure connectors. a 92-95 GSR or 94-95 Del Sol Vtec or 92-95 JDM/EDM Civic Vti harness will have vtec, vtec pressure and knock. You can add these wires to a CX/DX/EX harness too - buying another engine harness is just a way to buy something that requires less fiddling.
  10. Slammed90Lude
    milford, PA
    yeah, ^^^^^^ this is what i'm going to do on my GSR swap onto my 92 dx :)
  11. katman
    katman Member
    PASADENA, CALIFORNIA
    There's an amendment you should make to your almost perfect list:
    (optional engine harness)
    - using a US OBD2a or OBD2b integra engine harness
    (its fully compatible with any OBD1 civic /integra)
    using this specific harness will alleviate a person most of the modifications you just described, mainly the repinning of the distributor and injectors. The user will be able to use all OBD2 electronical engine parts without having to modify anything sensor, distritubtor, injector, and alternator-wise on the motor. The only wiring needed would be for the VTEC solenoid & knock sensor ... the knock sensor is obviously optional if the user decides to run a stock P28 or run a reprogrammed OBD1 VTEC ecu that has a disabled KS in the programming.
    :D
