Obd0 B16 Cps?
ad-8
Where is the crankshaft position sensor on a B16 located? Thanks.
i could be wrong, but i thought b16's didn't use crankshaft sensors, only b18's? b16's have a disc in the distributor that lets the ecu know where TDC is.
If you have a code for the "CKP" you will need to replace the distributer cause thats internal and can't be fixed unless rebuilt.
