obd0 b18a in obd1 eg civic
Discussion in 'HYBRID -> EG-EK / DC' started by bageorge21, Jun 10, 2004.
  1. bageorge21
    bageorge21 Member
    Cookeville, TN
    need to make sure i know all things that need to be changed to get a obd0 LS engine running in a obd1 civic. mounts, dizzy, fuel rail, injectors, starter, alternator? which ones will work and is there anything else to change out? please help a desperate honda owner out.
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    You want to replace the whole intake manifold (or at least the sensors, injectors, etc...as you have stated) And you want to get the right axles, 94+ integra. You can get the IM (or parts) off a 92+ Integra.
    Also you need to address the transmission, the pre 94 Integras had a cable tranny, and the post 92 Civics have a hydraulic transmission. You need to replace or convert.
