capmcatastrophy
So I have an 88 DX hatch and an OBD1 SOHC ZC engine that I'm getting ready to drop it. I know I will have to convert from DPFI to MPFI and will have to run an OBD1 ECU. My question is, do, or rather CAN I use an OBD0 injector resistor box to do the MPFI swap? Also, would the pinouts for the conversion be the same on, say a P28 ecu (if I wanted to put a D16Z6 head on maybe )
