OBD0 to OBD1 fan switch wiring
Discussion in 'ECU's, Electronics, and Tuning' started by Dark91zc, Feb 27, 2006.
  1. Dark91zc
    Dark91zc Senior Member
    Corona,CA
    obd-0 to obd-1 jumper right
    ok if you are going from your odb-0 side of the jumper the ecu pin is B-4and on the obd-1 side it is A-12 yellow and green :) i hope this helps
  2. Dark91zc
    Corona,CA
    sorry i forgot about that
    i am running a z6 thremo housing and i just added that plug and it had the right lengthen it :)
  3. jlicrx
    jlicrx Senior Member
    Colorado Springs
    it is just a switch - you can connect the wires either way - normally the switch is open and when temp gets to certain point it closes the switch to complete the circuit and turn the fan on
    here is wiring diagram:
