obd0 to obd1 Help!!! what distributor?
civic_hb_ pr
:confused:hi everyone i have a civic Si hb i am doing my turbo project i will be using a D16y7 into my ef.. running a p28 with hondata i have the obd0 to obd1 conversion harness ,the 4 wires o2 sensor and subharnes of it, this is a non vtec swap i am not interested to be Vtec .. i want to know what distributor do have to use and WHY? pplizz ...:mellow:
y7=obd2. Only obd1 d blocks are d15xx and D16Z6. Stop making things hard and use a Z6, hopefully you havent bought the y7. not sure what your gonna have to do, i say your best bet is either a OBD1 Z6 or d15 head, using respective stock dizzy's. Just use a Z6 and be done with it.
Z6 dizzy wont bolt up completely with you y7 head, you need a 0bd1 distributor that will bolt yo our y7 you want a d15b7 92-95 nonvtec. All 3 bolt holes will line up. Z6 will not.
