Obd0 To Obd2
Discussion in 'HYBRID -> EG-EK / DC' started by Ractive78, Mar 5, 2003.
  1. Ractive78
    Ractive78 Senior Member
    Virginia, USA
    The car I have is an obd0(1991 acura integra rs).The motor im getting (ITR) comes with a full uncut wiring harness, which is obd2. So could I just swap the wiring harness and not have change anything? If that is possible it sounds like much less of a hassle, then going and trying to convert everything to obd1 and trying to find obd1 ecu, distributer, etc...
  2. ekPhred
    ekPhred Senior Member
    tha's a nice motor that you have, but i think tha's its a hassle to do all that stuff. i dont think you can just swap out the harness's even if they're both tegs. i'm not even sure if they have kits where you can go from obd0 to obd2. i know they have kits for obd2-obd1, but not sure the other way around.
  3. Ractive78
    Virginia, USA
    Do you no of anyone that would know if i could just swap the harnesses? I know of someone that can make an obd0 to obd2 harness.
  4. EkHatch
    EkHatch Junior Member
    I can do this for you
    I will need both your original engine harness and the engine harness from the obd2 engine
    are you going to use the obd2 ecu?
    leave me email and I will give you a price, please tell me everything that you are going to use in the swap.
    bigblockcrx@lvcm.com
  5. pissedoffsol
