obd1 b16 in obd2 civic
Discussion in 'HYBRID -> EG-EK / DC' started by qtmac_mien, Feb 20, 2005.
  1. qtmac_mien
    qtmac_mien Senior Member
    running obd1 b16 in obd2 civic with p28...need obd1 dizzy or obd2?? ppl on automotiveforums.com says i can use either one...can i use obd2 dizzy and run a wire to the ecu?
  2. projectxspeed
    projectxspeed Senior Member
    New Hampshire
    it depends on how your car is setup, what ecu are you running?
  3. qtmac_mien
    i just gave u the setup im dogin " OBD1 b16 in OBD2 car with a p28..p28= OBD1 ecu.
  4. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    hmmmmmmmm this sounds very very familiar
    i wonder why? o yeah that is my set up...lol to answer that question OBD2 car means OBD2 dizzy point blank, the wiring of the obd2 dizzy is different then the obd1. the obd1 has two plugs and the obd2 has one big one! hope that helps you out
