Jayamashey
Just finished my swap OBD1 B16A into '89 SI. Tried to start but fuel pump does not start. I have looked uup otgher threads but no one had a solution. Verified wiring and from what I can see all is good. What connections would cause the fuel pump to not work?
Only odd thing about my set up is I am running a P30 ECU with a chip for a Vision P72. From my understanding this should work no problem. Also I did not connect he wire for the check engine since i didn't know where to connect it too.
Any help as to where to look would be appreciated.
