OBD1 b18c1 with obd1 p72
Discussion in 'HYBRID -> EG-EK / DC' started by eg6civic, Mar 8, 2008.
  1. eg6civic
    eg6civic New Member
    i got a 1995 B18c1 with the matching ecu...i'm going to put it in my 1995 civic CX hatchback so i need a little help....what do i do about the o2 sensor.?
  2. eg6civic
    eg6civic New Member
    also i was thinking...why cant i just take the harness from the chock tower down to the ecu? then would i have to wire anything in?
  3. eg6civic
    eg6civic New Member
    anybody got anything..................??
  4. Gen2Teg
    Gen2Teg Senior Member
    san francisco
    what do you mean what do you do about the O2 sensor? You plug it into the exhaust manifold. its pretty much plug and play for everything, just run the two wires needed for VTEC
  5. eg6civic
    eg6civic New Member
    well i was reading and people were saying about switching 1 wire o2 sensor over to 4 wire....and wire a knock sensor and evap. can. 7 wires in all i think...can i not just take the harness that sits on the shock tower and goes down to the ecu as well and that way i will be running the whole gsr harness right down to my p72? i shouldnt have to wire anything in that way shouldn't i?
  6. joshuaclifton
    joshuaclifton New Member
    west chester ohio
    you can also have your ecu chipped so it doesnt look for the o2. its what i did. its a quick and simple fix
  7. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    :mellow:
  8. LS_VTEC
    NJ
    Just make sure you wire in the knock sensor accordingly. Obd1 gsr's have them, unfortunately.
