206hondakid
Here is my problem, i swapped a gsr in my ef, converted it to obd1, ecu, jumper harness, i got new obd1 injectors (even though it wasnt needed and took out the resistor box and soldered the five wires together) and a obd1 gsr dizy. but im throwing code 4 and 14 ckp and iacv, had harness out, but only to extend a few wires and nothing got mixed up. I have looked at several pinouts for the dizy plugs and all wires are in the right spots. Does anyone see a problem? Did i miss or skip a step when i converted to obd1? the car just miss fires and backfires and runs like poo, i have skunk intake manifold, p30 pistons and delta stage 2 cams if that helps too. help!!!! and would it matter if it is out of a 99 integra?
