OBD1 conversion using obd0 dizzy?
Discussion in 'HYBRID -> ED-EF / DA' started by dominik, Mar 21, 2006.
  1. dominik
    dominik Junior Member
    My buddy told me I don't have to use a OBD1 dizzy to convert to obd1...I have the ecu jumper harness and 4 wire oxy sensor.
    I;ve read that everyone uses a jumper harness to use an obd1 dizzy....
    Is what he's saying true?
    At first he said to convert the dizzy to obd1 but then he said it's not even neccessary and that the b16 obd0 dizzy will work with a p28....
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    OBD0 distributor will not work with OBD1 ECU
  3. ripperbone
    ripperbone angry bear
    Oklahoma
    :werd: this man speaks the truth,
  4. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    Your buddy is a fucking idiot.
  5. Black Widow g2
    Black Widow g2 *princess*
    California
    i'm with everyone here.
    you can NOT use an obd0 distributor.
    you CAN splice the wires from the obd0 harness to work with the obd1 distributor and plug.
    if you can get that obd0 dizzy working with a p28, i will paypal you 100 dollars.
    <span style="font-size:8pt;line-height:100%">not really... but i'll pretend like i will</span>
