Obd1 Ecu
Discussion in 'ECU's, Electronics, and Tuning' started by civism, Feb 26, 2003.
  1. civism
    civism Banned
    i have a 94 dx with GS-R ecu OBD1.....do i just plug in the GS-R ecu and wire vtec up? or do i have to do a wire conversion? will the DX P06 power the GSR? i heard that the P28 will power the GSR? is that true?
  2. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    Sort of, you need to add VTEC solenoid, VTEC pressure, Knock sensor and EVAP wires.
    It will, but it will not control VTEC, nor the secondary butterflies
    Yes it will, but again, it will not control the secondary butterflies
  3. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    it'll work.. but forget running it to it's fullest potential. check your PMs
