obd1 engine code?
C-Bye
Member
I got the swap in it turns over, yippy. Used a little starter fluid ran for about 5 seconds, now the obd flashs= two short flashs and pause then four quick ones. I read my chilton and can't fiigure out what the code or codes are, any help?
2 long flashes = Electronic Load Detector
4 Short Flashes = Crank Angle Sensor
I swear my CB7's throwing a code 25. I thought that long flashes meant 10 and short flashes meant ones. I get two long flashes and five short flashes.
but he said code 24 or 25...to my knowledge OBD1 doesnt have either code...which mean there are two problems...there is no pause between the long flashes and the short flashes if it is a single code. hence he has 2 codes...probaby 20 and then 4 or 20 and then 5.
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow
