obd1 engine harness?
mad_hatter
Its Da Mad Hatter
Does anyone have some info on switching the shock tower plugs to obd1, i want to use the stock engine harness with my stock, ive seen it done, just cant find anything on it, thanks.
and yes i already have the ecu harness wired
I don't reccomend trying to pin out the harness get the right harness for both sides if you are converting and then run them through. It is a lot of disassembly to change everything over though.
even if i decide to keep the original harness i would like to find to pinouts for the plugs still so i can do a better wire tuck, a few plugs have been cut off too
