I've done quite a bit of searching and I am still kind of gray when it comes to this swap... The motor is an OBD1 GSR Motor... So, from what i've found so far...
Mounts
- 99 Civic Si Rear "T" Bracket
- 99 Civic Si Timing Belt Bracket
- 99 Civic Si Front Tranny Torque Mount (Re-use stock rubber mount under framerail???)
- 95 Del Sol VTEC A/C Mount (Re-Use stock rubber Mount under framerail???)
- OEM Upper Tranny Mount
- OEM Driver's Side Mount
Shift Linkage
- 94-01 Integra
Axles
- 94-01 Integra axles w/ 94-01 Integra Intermediate Shaft
Wiring
- If it's an EX, you won't have to worry about the 3-wire to 2-wire IACV fix, so i could run a 96-98 GSR ecu, or run an OBD2a-OBD1 conversion harness and run the OBD1 p72... Also, I will need an OBD2 DOHC VTEC Dizzy.
Anything I am missing?
Also, any comments on what under framerail rubber mount to use? OEM or whichever the mount is from?
Mounts
Shift Linkage
- 94-01 Integra
Axles
Wiring
