OBD1 IM on OBD2 B18C1
HCarPhreak
I went to a juck yard lookig for a OBD1 B18C1. The guy at the junk yard said that he had a 96 B18C1 complete swap that he could put a 95 intake manifold and give me a 95 ECU with. Will this work? Also, will an OBD1 distributor work on this motor or is rewiring the obd distributor easier?
:) if your car is obd 1, the easiest is throwin on a v tec obd 1 dizzy! simple bolt on!
and yea the intake is cool, you REALLY only need the injectors but if he is gonna give you the whole intake, why not!
get him to throw in a b series obd 1 alternator, youll need that, saves you from re wiring!! again, a simple bolt on. keep it simple! :)
