I read the references section and a couple of other tech articles on hybridgarage. I have a 96, with obd1 b16a, obd2 distributor and itr intake manifold. I am using my 96 DX harness with a hasport overlay harness for vtec and such.
All tech forums say is "wiring harness modifications needed". Has anyone done this? The 2 sensors I'm having problems with is the Idle Air valve and air temp sensor, which is causing my car to be running extremely bad.
I was reading about obd2 - obd1 conversion on a gsr and there was a discussion about wires seeing 12V, is this a problem??
thanks
thanks
