Obd1 injector wiring help
Discussion in 'HYBRID -> ED-EF / DA' started by HATCHET_HONDA, Jun 27, 2008.
  1. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    ok i have a dx harness and im doin the mpfi coversion for my b16...i have the injector harness which has the four yellow/black wires i can solder to. i know to connect the 2 same color wires together from the dx injector plugs but that makes only 5 wires...the dead end plug for obd1 injectors has 7 wires on it..wheres the other 2 wires?
  2. t3t4delsol
    t3t4delsol New Member
    York, Pa
    there's a sensor that plugs in between the injectors. I cant think of the name of it off hand, but think that runs along with the injectors
  3. HATCHET_HONDA
    hobart, indiana
    sensor??do i need it?? i didnt do that on my first hatch
  4. Justin91civic
    Justin91civic New Member
    Nashville, Tn
    If I am not mistaken you have to have the injector resistor box on the obd1 conversion unless your car was originally mpfi. Are you doing the mpfi swap as well with this car?
  5. HATCHET_HONDA
    hobart, indiana
    ..its a 90 dx hatch..swappin in a b16 so its runnin obd1..no resistor box needed just a dead end plug. ..i did the conversion before from dx to si but i stayed obd0...im just wandering if i pluggin the 5 wires to that dead end plug will be ok instead of having 7 into it
  6. Justin91civic
    Nashville, Tn
    When I had to cut up a obd1 engine harness out of a eg I found that dead end plug it had a cap on the end of it and it looked like they all connected together using the cap that you can take off. I did not see where the other end of the wires went to I just knew that 4 were for the injectors and 1 was to the main relay under the dash. I am not sure about the others but you might have to find a detailed wiring diagram out of the car that you took that motor from.
  7. HATCHET_HONDA
    hobart, indiana
    yea i gotta find out what the hell the other 2 yellow/black wires go to..... my 90 si is converted obd1 and it only has 5 wires in the plug and works fine.. im thinkin the other 2 arent needed..hopefully
  8. Justin91civic
    Nashville, Tn
    The way it looked like it was a test harness so a person will not have to go and disconnect the wires from the sensors and use it to check the resistance on the wires and plugs. When I hacked up that harness with that plug the other two wires led to some plugs that I had no use for.
  9. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    yo homie. all the yellow/black wires are power wires for the injectors. then each colored wire is for each injector's signal wire. the yellow/black wires are powered via the main relay, and should all be connected together at a junction of 5 wires (1 lead, 1 to each inj).
  10. HATCHET_HONDA
    hobart, indiana
    ok.. i wired everything together last nite...all the colored injector wires are connected as they should. the 2 yellow/black wires from the dx injectors (relay) are soldered together to make 1. soo that makes 5 wires into a dead end plug, sound righ?
  11. YBLEGAL
    NW Indiana
    is yours like that?
  12. HATCHET_HONDA
    hobart, indiana
    yep PRETTY MUCH... and that explains what the other 2 wires are for..iacv lol which that is wired up already..sweet diagram yo
  13. YBLEGAL
    NW Indiana
    lol thanks. bordom set in, and for some reason i went with mspaint instead of photoshop.
    ya it also (in my car) powers the Evap Canister Purge Control solinoid, and the primary o2 sensor. i would post up the honda diagram, but i'm looking at the back of my haynes manual.
    good luck man! hopefully your nearing completion! i am!
