obd1 intake manifold on obdo car... Some issues.
Discussion in 'HYBRID -> ED-EF / DA' started by phyregod, Jun 22, 2005.
  1. phyregod
    phyregod !!YTINASNI
    Central Texas
    Hi, just like the subject says, this is my swap:
    1990 CRX si
    90/91 b18a1
    90 teggy computer
    90 CRX si harness
    Problem is I have a 93 b18a1 intake on it. The issues I am having are code 14.. EACV/IACV The plug is the same, and the units look similar, but their bolt patterns are different, what I am wondering is, will an OBD1 EACV work on a OBD0 computer?
    Also, the engine is running, but it still has OBD1 injectors in it... The resister box is still hooked up.. Is that supposed to happen? I thought it wouldn't run, I was cranking it to get the oil through the motor and it fired right up?!?!
    I would appreciate any info... Thanks!
  2. Dark91zc
    Dark91zc Senior Member
    Corona,CA
    the eacv/iacv does not matter what obd it is :) now here is the question did you get the im for the junkyard or buy it from a private party, cause it might be bad and need to be replaced. the injectors are fine but out might want to get 0bd-0 injectors too be safe since the obd-1 injectors dont run with a resisterbox. also on the 93 teggy im is the bolt pattern wide or narrow???
  3. phyregod
    phyregod !!YTINASNI
    Central Texas
    The '93 is more narrow than the '90.
    Pics:[​IMG]
  4. phyregod
    phyregod !!YTINASNI
    Central Texas
    Switched injectors to OBD0.. works like a champ. still throwing that code though.. I've got to find another EACV..
  5. Dark91zc
    Corona,CA
