OBD1 pinout question.
Discussion in 'ECU's, Electronics, and Tuning' started by nightrider45, May 28, 2007.
  1. nightrider45
    nightrider45 Junior Member
    I'm was looking at the OBD1 pinout diagram and i was looking at pinouts B3 and B4. I have an automatic tranny and i was wondring what will those be connected to? would those have to do with anything about the 2 solenoids thats on the tranny that can cause a error ecu code number 19? or is it D18 to correct ecu code number 19?
    And my fan for my radiator is not turning on. Do i have to connect pinout A14 to the radiator fan?
  2. custompainter
    custompainter drive it like U stole it
    central CT
    FFS TechNet Home [​IMG][​IMG] FFAQ [​IMG] Downloads [​IMG][​IMG][​IMG]OBD1 Civic / Integra / Prelude ECU Pin SchematicsAuthor: Katman / Created: April. 06 / Last Updated: September. 06
    SYNOPSIS
    This article exploits a combination of ECU pin locations and wire colors for all M/T '92-95 Civic / '92-95 Integra / '92-95 Prelude VTEC and NON-VTEC vehicles.
    OBD1 PLUG CONFIGURATION
    Below is an example that shows the common onboard male connectors for a Honda OBD1 ECU.
    Take note of plugs: A, B, and D.
    The 4-plug OBD1 connector image below is proof these do exist and are usually found on JDM AUTO 92-95 Civic, Integra, and Preludes.
    Sorry - I do not have pin schematics for the JDM 4-plug OBD1 ecu! Although, connectors A B D should technically be the same pin locations as a 5spd 3-plug OBD1 ECU.
    ADDITIONAL INFORMATION
    These pin-out locations were cross-referenced with OBD1 Civic/Integra/Prelude Helm's service manuals.
    The information in this article applies to:
    • All US & JDM OBD1 (92-95) M/T civic ecu's
    • All US & JDM OBD1 (92-95) M/T integra ecu's
    • All US & JDM OBD1 (92-95) M/T prelude ecu's
  3. custompainter
    central CT
  4. nightrider45
    I looked at that already, but i'm confused, thats y i'm asking the question, to see if anyone knows. I see the pinouts on that diagram but is my statemetn true in the first post?
  5. custompainter
    central CT
    i believe so but your going to have to trace out witch wire goes to witch solinoid they should be color coded
    and i dont think A14 goes to anything you might just have a bad sensor thats why your fans aren't coming on
  6. nightrider45
    i checked the solenoids for the tranny but there different color wires. instead of tracing it back i was just going to spice a single wire to the ecu.
    And thanks for telling me about the A14 pinout. I really meant the A12 Pinout. The fuses and sensor are fine. It's just i beleive the person that did some of my wiring never connected the fan because he didnt connect my vtec, oil pressure, knock sensor, Ckp-p ground and ckp-m ground. And the more i look at my wiring the more i find out more things that are not connected. And the way i found this is was by changing the cluster of my car. I found out that there was never a bulb for the check engine light, there for i thought everything was fine. Now i'm fixing things on my own. (more secure).
  7. custompainter
    central CT
    that sux
    let me know how you make out
