OBD1 throttle body on OBD2 B20... ?!?
Discussion in 'HYBRID -> EG-EK / DC' started by 94GSRB20swap, Dec 29, 2008.
  1. 94GSRB20swap
    94GSRB20swap New Member
    i used the harness from the car when i dropped in the motor... i cut the plugs off everything except the throttle body which i had to use off the gsr because the b20 map sensor was busted. so theres obd2 plugs everywhere else except the tps sensor and map sensor... would this cause the obd1 ecu i have to throw those codes?? what can i do to fix this issue?? also i have a crankshaft position sensor code. what and where is this at? PLEASE HELP!! this has thousands into it and now i have nowhere to turn except here. its in limp mode becuase of these issues... what can i do?? ill replace or buy anything i need.
