Originally posted by jdmslim9295@Sep 25 2004, 06:47 PM
you would probably come out better using the sohc zc manifold, should have a little bit better runner design since the dx manifold was designed for optimal fuel efficiency
[post=394682]Quoted post[/post]
Originally posted by Calesta@Sep 27 2004, 06:10 PM
It's probably more restrictive... but if you're worried about your intake manifold not passing smog, won't you have the same problem with the JDM engine in your car? If the engine will pass, then the IM should pass along with it.
[post=395446]Quoted post[/post]
