OBD2 B16A and Emissions
Discussion in 'HYBRID -> EG-EK / DC' started by daf, Jan 20, 2007.
  1. daf
    daf Junior Member
    Ok, Ill make it quick and simple. I have a 98 EX with a 97 SiR II B16A in it I installed this summer. I need it to pass emissions ASAP.
    What do I need. I already bought a p72 which I have been told will work, and I am doing the CKF fix to take care of that. I am picking up a Purge Selinoid tomarrow as well.
    What else will I need cause I cant find ANYWHERE that will give me a half desent write up.
    I am in NC and it only needs to pass the OBD2 plug up thing.
  2. divisii
    divisii Member
    You cannot legally swap an earlier model year motor into a newer vehicle. So your ok if they don't check. Your car will need to blow readings within the parameters allowed & you need to have smog equipment for your model year - perhaps use the SI (DOHCB16A2) parts to get there - pre/post cat o2 sensors, any (?) catalytic converter, EVAP, etc.. As long as your not throwing any CEL codes you should be good.
  3. divisii
    divisii Member
    ... oh, I've found my 96-99 honda manual to be the single best buy to sort is all out.
  4. Domi31
    Domi31 Member
    Nor Cal
    You may throw a CEL becuase the USDM ecu will look for VTEC oil sensor, and the JDM motors dont have one.
    I got this CEL when I went with a USDM OBDI ecu on my JDM motor, I just spliced my VTEC solenoid wire with VTEC oil presser on my harness, so the ECU was seeing a signal for oil, worked perfect
    I'm sure you can do the same thing with the OBDII ecu, pinouts are diffrent
    I'm shure it will work, but I also think the CEL only comes on when motor tries to engage VTEC becuase the USDM ecu looks for correct oil pressure (safty thing) and I dont think they will take the motor that high up the RPMs, so if that is the case no worries, but just throwing that out becuase if you have a CEL your screwed.
    good luck
  5. untitledsince89
    untitledsince89 New Member
    Where in NC do you live I'm in winston and have a shop u could get it done at
