obd2 b18b1 swap 5th gen
Discussion in 'HYBRID -> EG-EK / DC' started by HatchSpeeD, Nov 18, 2003.
  1. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    When doing a obd2 b18b1 swap into a 5th gen civic hatch, is it true that all you need is the obd-1 ecu and thats it. No extra wiring, or changing of the distributor and all that crap. K thanx B)
  2. ksrcivic
    ksrcivic Senior Member
    Sacramento California
    OBD1 ecu is a start. your stock wiring harness should work just fine, you will have to lengthen the Air Intake Temp Sensor wires so they will reach the placement of the OBD2 AIT which is on the intake tube and not on the intake manifold like on the OBD1 cars. You will need to use an obd1 distributor tho, or you can change the plugs on the OBD2 distributor and make it work too just match up color for color. As well as the injector plugs will have to be changed to the OBD2 plugs, if you are using an OBD2B(99-00) motor the O2 sensors plugs are reversed as well, other than that it should be fine. Hope this helps
  3. InsaneCivicSedan
    InsaneCivicSedan Junior Member
    Tampa,FL
    also the alternator will not work so you will have to get one from a 94-95 (obd1)teg or something along those lines....
  4. 92civicb18b1
    92civicb18b1 The Trisexual
    Why wouldnt the alternator work? That doesn't make sense, the plug may need to be changed but not the alternater itself.
  5. ksrcivic
    Either or in this case... im sorry i forgot about the alternator, but you can use an OBD1 alt or change the plug, again just match color for color.
  6. SolReaver
    SolReaver Senior Member
    No, no, no. Pretty much everything you said is incorrect.
    the obd2 dizzy will work just fine
    you dont need to switch any alternator plug
    o2 sensor plugs in just fine and works prefect
    :no:
    omg :bash:
    my motor has the ait sensor in the EXACT same position as the obd1 civic motors
    I have an obd2 b18b1 in a 5th gen civic(del sol)
    here is the definitive answer-
    ALL you need is the complete engine swap with engine harness, unplug your old engine harness at the strut tower and plug the new one in. Plug an obd1 ls ecu in. THATS IT.
    btw if you need an obd1 ls ecu here you go
    http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=2443100960
  7. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    Thanks sol. Do you throw any cel's? I had a feeling with the b18b1 it was like that, or so I heard.
  8. SolReaver
    Nope no cel's. engine runs great
    good luck
  9. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    So with the obd2 harness, there is no extra wires or plugs? Just plugs right in?
    Thanks again B)
