obd2 gsr in obd1 hatch
5hiftdhatch
I picked up a 98 gsr swap for 2000.00 i got engine ecu tranny axles shift linkage wiring harness and rear disc setup.
My questions are what do i need to do to put it in my Vx hatchback.
Do i have to wire vtec . My car is a vtec-e
Do i need the jumper harness
Anything im forgetting thanks
youll need an obd1 b series distributor. fuck the harness. the engine harness should already have vtec wired. just put it in and have fun
Most importantly, you will need mounts. As for the ecu, sell it. Your car is obd1, your engine is obd2. You will need the following:
1) mounts for b-series into EG chassis
2) obd1 ecu chipped for b-series
3) obd1 distributor
4) larger fuel pump (recommended--walbro 255)
I was told that the mount mounts from the integra will work ??
Will my distributor work ??
