OBD2 harness TPS
werdupEGs
Hey on an OBD2 integra harness has anyone noticed 2 plugs that fit the tps? Mine is like that.
Yep one plug goes to the TPS and the other goes to the Map sensor. TPS has a green/black wire on one side and a yellow/blue wire on the other. The Map sensor has a yellow/red wire on the left, a green/white wire in the middle, and a red/green on the right. Keep in mind the colors pretain to 98-01 Integras.
ooh ok.
Its actually in a 93 civic.
I have my map sensor hooked up via the plug that is hanging off the fiirewall (map sensor is mounted there on that model civic stock.
should I try unhooking my factory plug and hooking up the one from the teg harness?
The car seems to run fine now however. well except it does have a cel which I am checking tommorow after tuneing up the engine.
