obd2 swap into 91 integra obd
Discussion in 'Integra' started by Orochi420, Apr 8, 2008.
  1. Orochi420
    Orochi420 New Member
    gr,MI
    i have three integras a 96 se,95 ls (bought with timebelt broke valvetrain damage),and a 91 ls. the 95 block is going to be used in the 96 for a lsvtec. the engine in the 96 runs good still and the 91 burns oil. so i want to swap the obd2 from the 96 into the obd 91. but having trouble finding specifics on what parts i need or can use from the 96 other than head, block, ecu, distributer. help plz b4 my91 dies she will be driven the most.
  2. BrutalB83
    Rochester Hills, MI
    Just use the accessories from the older engine and run it as OBD1.
  3. Orochi420
    gr,MI
    the 91 is obd0 and the b18b is from a obd2
  4. spaded
    spaded New Member
    MA
    My performance shop i go to was able to put OBD1 parts in my car no problem they said that acura's are a little different then honda's and that the 90-93 integra is obd1 irreguardless
  5. BrutalB83
    Rochester Hills, MI
    Not necessarily true. I'm fairly certain that some of the 90-91 models did have OBD0...
  6. spaded
    spaded New Member
    MA
    thats what i read and i even argued wit the guy bout it but hes saying its obd1 and i paid for an OBd2 jumper harness, i could be mistaked im still fairly new to honda
  7. Orochi420
    gr,MI
    im keeping it obd0 and only using the head/block from the 96. a for b
  8. kaoss
    kaoss New Member
    That's actually wat I was tryna do was swap a b18b in my 91 ls
  9. DumaDa9
    DumaDa9 New Member
    You can use the entire swap from the 96 in your car. If you dont care about being able to rev the motor to 7200 you can leave your stock ecu and run it to 6500, you can use the 96 swap, put on the dizzy and manifold from your 90 integra and you'll be fine
  10. suspendedHatch
    suspendedHatch audio/security
    All 91's are non-OBD. If you want to argue with me post pics of your ECU harness, the emissions label under your hood, and/or your VIN.
  11. DumaDa9
    DumaDa9 New Member
    also referred to as obd0...
